TRX 1 Connect +
philacop
Clifton Hgts PA
Question, when programming a connect plus system in a whistler trx 1 are lcn 1 say 451.000 channel 1 and 2, lcn 2 say 452.000 channel 3 and 4 ect??? same way uniden does it. Also if the system skips say ch 9 and 10 would you skip that lcn?? example system has channels 1,2,3,4,5,6,7,8 11,12
buddrousa
Do you have a TRX-x I am looking at my TRX-2 software and I only see a place to enter the frequency not a LCN. You can only enter frequencies and I have entered al listed frequencies for a system/site and mine is working great as far as I can tell.
troymail
Silent Key
The Whistlers don't care about the LCNs (much easier). Just enter the frequencies - order doesn't matter.
philacop
Clifton Hgts PA
Yes
when using the whistler software programmed in as trunking dmr then site info then in frequencies section left first column says lcn 1 ect..
trido
Retired 32 years scanner sales
Southern In
right there IS a LCN col like you said on left .
Yes
troymail
Silent Key
...but note that that same LCN column appears even on P25 site frequencies... It's probably just a generic widget thing for systems where programming the LCN matters (EDACS, etc.). However, from my experience, the LCNs for DMR systems do not matter to the Whistler radios...
trido
Southern In
You are right I tested a con+ system I changed KNOWN LCN still track just fine.Interesting.
jcardani
Orlando, FL
I think the reason for this is the Whistler scanners do not use the talkgroup data in the control information as Eric Cottrell stated in another thread. They elected to use the talkgroup data on the voice channels instead. While this makes things simpler because the LCN is not needed, it may cause a delay in channel acquisition, especially on larger or busy systems.
Tom (philacop) I'm interested in seeing if the Whistler can receive Cap+ systems with RAS implemented such as the one the hotel uses near the PHL airport. I've asked countless times on the forum about if the Whistler handles RAS and received no answers.
thanks!
Gilligan
Hagerstown, MD
Does the TRX-1 have the ability to show system ID and site # like the Uniden displays in conventional mode?
