Icerider518
- Joined
- Aug 18, 2023
- Messages
- 7
Here is a nonexhuastive numbered list of problems with this radio:
#1: This model radio, and I have had 3 of them (2 of them were returned becuase they totally froze within the return window) is plagued with errors and it never really just works. It consistently needs to be rebooted and reprogrammed. It is super buggy, super slow, and bottom line, it is just unreliable.
#2: The technology is at least 10 years old. The problem with that is the operating system and all your files are run from a SD micro card. You cannot use a modern high speed, high capacity SD micro card becuase they are not compatible with the 10 year old board in the radio. Scan speeds are unacceptable.
#3: The construction is super chintzy. The thin plastic is super light duty and the radio simply very fragile. Forget about taking it out into the field.
#4: The USB cord will not charge the batteries to full capacity. In order to get a full charge, you have to take the batterries out and put them on a charger. Using the USB, the charge will be about half full, which will last you around 2 to 4 hours depending on what kind of scanning is being done. Again, forget about field use.
#5: There is no search and store functionality. The advertisements tout the spectrum sweeper capability. "Spectrum Sweeper allows you to watch for near-field activity on selected frequency bands . . . Once an active frequency is found, the transmission is played through your scanner’s speaker, and you can quickly store it in any of your scanner’s memory locations." What they are not touting is the fact that the user has to sit there and listen for the traffic and then manually (and you better be quick) store the frequency. In most scanners (e.g. Uniden) the frequencies that are found will automatically and seamlessly be stored to a chosen location so the radio can by run independently with no human interaction for days (or longer) and then the discovered frequencies can be inspected at the convenience of the operator.
In summary, this radio is a waste of money. Even if it was not buggy, (which it is) it would be WAY to expensive for what you get. There is a litany of other problems that I won't bore you with. I'll give it 2 stars out if 5 becuase it does have a great reciever. It is super sensitive and gets good reception. And it is capable of monitoring a wide array of transmition types.
I am still waiting for a company to make a super scanner. Which to me, would have all the functionality if the latest top of the line Uniden, but come in a case similar to a Motorola XTS or Mototurbo or at least a high end marine radio (durable and water resistant) and have the same sort of battery and charing cradle.
