- Joined
- Dec 1, 2021
- Messages
- 22
Hi all ! we have Motorola cm200d Two way radios VHF and when I pick up the frequency with a whistler TRX 1 there is just white noise ;am I doing something wrong or is the TRX 1 not capable of picking up that traffic ?
Here are some good details regarding the FCC Emission Designator once you locate the license.Ok I will have to do more research then .
If you provide the frequency and city/state you are located in we may be able to assist.Its a little over my head .
Yes, you can send me a private message. Just click on ScannerSK on the left and "start conversation" to send a private message.Can i reply privately
The TRX-1 can receive DMR out of the box. There is no upgrade required. It cannot trunk track DMR trunked systems but will still decode unencrypted DMR transmissions.I would download the upgrade to decode DMR signals if you have not already done so.
OK that is where I messed up ,it was on auto ,I will switch it over to DMRIf you set the mode to "auto" it can only receive analog and P25. For DMR you have to program it as DMR.
Exception here is the "tune mode", which can receive all supported modes.
Would I leave the color code and time slot setting on "Any" though IF I am not sure on color code ?OK that is where I messed up ,it was on auto ,I will switch it over to DMR
