TRX-2 4.0 Update
gvodvarka
Ontario, Ca.
Cannot do CPU update. Fails every time. CSerial::Open - CreateFile(\\.\COM6) failed, GetLastError()==0x00000002.
milcom_chaser
Is this the only update that has failed? or is this true for all updates (Firmware, DSP, EZ Scan, etc).
This looks like a COM port issue between the TRX and the PC...
Do you have another PC you can try to update the TRX with? That would isolate the problem further...
AggieCon
Texas
This might be a EZ Scan problem.
Do the CPU and DSP updates before you update EZ Scan and see if it works better that way--at least for those who have not yet updated.
Before today, when was the last time you updated the EZ Scan software?
kikito
North Pole, Alaska
I was having the issue where the CPU update kept failing but then I disconnected the cable from the scanner side then while holding the MENU key down, plugged it back in. At that point it forces the radio into the CPU update mode properly and then the update worked right away the first try.
gvodvarka
Ontario, Ca.
TRX-2 CPU Update
Downloaded the latest version this morning and it Completed and the scanner starts working but when I go to a menu item I get a Error Detected Please contact Whistler Service for Assistance Code:1-01 I also after turning off I the the original Error. Downloaded 3.2 and it fixed all the errors. I guess there are many bugs in 4.0.
gvodvarka
Ontario, Ca.
They sent me 4.1 CPU and l think it's fixed. They also updated the EZ software.
