Trying to import RR Web Service database data to my scanner in PSRedit500, but getting an "unable to load WSDL file/location" error
dratsabdeye4
I made sure my user/passwd is typed in correctly, but every time I try to import data to my scanner in PSRedit500, it just throws up an "Unable to load WSDL file/location, an invalid character was found in text content" error, so I can't import any data. How do I fix this?
AM909
Radio/computer geek
SoCal
This search suggests that it's a problem with a specific database entry. Is there any more detail in the error message? What are you importing? Can you narrow it down to a particular system, county, state, etc.?
dratsabdeye4
The location I'm trying to import data (frequencies for local PD/Fire/EMS) from is Montgomery County, Virginia. I am not sure how to tell if a particular entry is messed up; I am still pretty new to scanning.
The error message says in full:
Unable to load WSDL file/location: http://api.radioreference.com/soap2/index.php?wsdl&s=RPC&v=15. Error [An invalid character was found in text content. Line 1]
Ronaldski
MI DB Admin
Bay City MI
Conventional or Trunked? When you go to Agencies: what are you selecting in the drop down, then same on Category: and Sub Category: ?Exactly what agency selected causes the error. I have tried to replicate the error and downloaded a bunch of items from Montgomery county in psredit500 and have not received an error.
dratsabdeye4
Conventional. And I can't even get to the Agencies part; it gives me the error a second or two after I click the "query RR Web Database" button in psredit500.
Ronaldski
MI DB Admin
Bay City MI
No issues here doing the same thing, be sure you have Version 1.93 release 17 build 20. You can see under Help and select About in Psredit500
Then while your there in Help select Check for Updates.
If you already have that version, download and reinstall.
