mlfd612
Hi all,
I work on Fort Benning, Ga and want to monitor the airfield better (KLSF/Lawson AAF) from home.
I am not new to scanning and basic antenna theory, but wanted some good outside advice from the wealth pool of it here.
I currently have a scantenna at 750' (home elevtion is 730' plus a 20' mast), and the transmitting antenna is roughly 363' in elevation at 24.5 miles line-of-sight distance. There are no terrain obstacles between the two points, so essentially I am a bit higher than the transmitting station.
I can currently hear the more elevated aircraft transmissions fairly well, as expected.
My goal is to try to hear the tower transmissions on 121.7/119.05 AM, as well as to better hear the aircraft when they are lower in the traffic pattern. I will be using different scanners, but currently it is on an old base station of a Uniden BC898T. Probably would monitor some on the same antenna but downcoupled to RTL-SDR's sometimes.
My cable run from the antenna is fairly long at 90' of RG-6 line, but has served fairly well so far.
I'm thinking some kind of directional antenna? Question is two fold then, I suppose:
1. Discone etc. vs. directional or amplified antenna, and...
2. Would it really be that much of an improvement, or is it an unreachable pipe dream at that distance?
Thanks all!
Thanks all!
