Two S D questions
FrankM
Sioux Falls, SD
Greetings from Sioux Falls ! I have a couple of questions related to Sioux Falls and to Watertown. 1) Does anyone know what the frequency is, if there is one, for the paging system to the Sioux Falls Fire Stations ? 2) What the Taklkgroup for the Watertown Fire Department ? Radio Reference has nothing for the FD. Thanks !
The database lists a VHF freq for paging and dispatch but the are also listed as using the SD State Radio system listed in the next section below. Sioux Falls Fire Rescue is also talked about in the RR Wiki.
Try this site, but are you sure they aren't dispatched through the county?
Also Watertown has frequencies on the SD State Radio system including EMS & PD
I disagree, the database and links above all mention the Fire Department
FrankM
Sioux Falls, SD
I have checked Coddington County above again, I see NO fire Department info. I don’t know where you are seeing it.
That's strange, same link as above it is the top two listings, also the other link I included wasn't RR it was another site. Pulled it right up for me, again. It is also in the other links, I wouldn't post them if it wasn't there.
FrankM
Sioux Falls, SD
THANK YOU very much for this info. I was looking every time under the Trunking system list
Medic42
Canton, SD
Sioux Falls Fire is on P25 system
