Two Tone decode
Able to program the SDS100 to allow mute until alert like a regular Minitor does on selective call?
  • Yes.
    Votes: 0 0.0%
  • No.
    Votes: 0 0.0%
  • I have no idea.
    Votes: 2 66.7%
  • Do we look like tech support?
    Votes: 1 33.3%
  • Total voters
    3
  • Poll closed .
jhsands
Texarkana, Arkansas
I found the below on the Uniden website (SDS100 True I/Q™ Digital Handheld Scanner) for the SDS100 and am wanting some verification. Are you able to program to allow mute until alert like a regular Minitor does on selective call?
"Fire Tone-Out Standby/Tone Search – Lets you set the scanner to alert you if a two-tone sequential page is transmitted. You can set up to 32 Tone-Outs. The scanner will also search and display unknown tones "
Eng74
Kern County, CA
If you are using Fire Tone Out when you have it on Standby you will not hear anything. Once a programmed tone is detected it will open and you can hear the dispatch. I normally have my Tone Outs set to infinite when it is alerted that way it stays open if the dispatch is taking awhile to get out the info or more stations are being toned out also. Unless you need the 30 tone I would get a 325P2 with it 10 tone outs and is a lot cheaper than the SDS 100.
