Has anyone noticed an issue with low frequency tones not being detected? I have a couple departments that use tones lower than 400, and they don't seem to get detected.
Any thoughts?
Any thoughts?
I agree with Dave, the low ones are a little more challenging. some volume helps. I have several in the range of 313-330 and it detects them reliably.I found low freq tones need more input volume. Since increasing my input volume and using a better antenna (to pull the audio out of the weeds) that my low tones are working well.
Any thoughts?
I think I have streaming audio working alongside TTD on a Pi. Haven't had any pages yet to know that everything is working 100%, but it appears ok. I followed the instructions here to get the streaming audio going (installing darkice and icecast):
Live mp3 streaming from audio-in with DarkIce and Icecast2 on Raspberry Pi
To use pulseaudio as the audio source, in the darkice.cfg, I simply changed this:
Code:device = hw:1,0
to this:
Code:device = pulse
Edit: I found that when trying to get darkice streaming to autostart along with TTD, it caused some issues, so I now have my cron jobs set up so that TTD starts immediately, and then darkice starts two minutes later. This seems to work so far. My crontab -e looks like this:
Code:@reboot screen -dmS ttd-screen /home/pi/TTD/startTTD.sh @reboot /bin/sleep 120 ; screen -dmS darkice-screen darkice
Have fun!
Andy
Has anyone had luck in implementing a RR feed from a pi that is also runnng TTD? I have been trying and can't seem to make the connection from Darkice to the pulseaudio source. If someone has done it, then i expect that I have missed something simple, otherwise, the troubleshooting may have to go deeper.
I have a RR feed set up and functioning on a standalone pi, just can't make the combo one work.
Any thoughts?
Jim
Jim,
I do have this working. All I did was set device = pulse in darkice.cfg along with changing the other parameters needed to stream to RR. I can send you my darkice.cfg when I get a chance.
Andy
I see on the TTD google map that there are some flames icons but mostly pushpins identifying locations where TTD is in use. Does anyone know how to get a Raspberry Pi icon that we could use on the map identifying those running TTD on a pi?
Jim,
Andy
Andy,
I have been trying to put together a card image that will work out of the box for Pi users. I have been using the TwoToneDetect63pi.pyc file included with the v63 release. When running this I get an error message 'audio_threshold' not defined when I run the program. I can't seem to figure out the problem and am now wondering if it is in the v63 file. Attached is the screen information showing the error message as well as the config.cfg and tones.cfg information that I am using.
Your thoughts?
Jim
I'm new to the Raspberry Pi World and I have been trying for two days to get TTD installed on my pi with no success as of yet. I have followed the instructions on TTD website on how to do this but I'm not even sure where exactly to copy and paste the modules and such. I just unboxed my Pi two days ago and installed NOOBS and I am using Raspbian. If someone could please give me some major assistance I would greatly appreciate it.
Jim,
I ordered a cheap Chinese usb Sound card and still waiting on it to arrive, do I need to wait for it before I begin to install TTD on my Pi?
Jim,
