Tyt th9800 transmitting problem
bpbower88
New to radio world as far as transceivers go. I'm a captain for a local fire department and I've recently added a mobile radio to my vehicle. The tyt-th9800 I know it's a Chinese cheapo but it had the dual band capabilities i needed at a good price since my county uses VHF and uhf for public safety. I have a mag mount pretuned nmo stubby on the trunk. Now my issue I have programmed the radio with what I thought was correct settings I can hear all the right radio traffic on all channels I programmed but when it comes to transmitting to central dispatch they can't hear me but anyone of my guys on the department can hear me fine on there portables. I'm not sure if I've missed a setting or what. Thanks for any help
jonwienke
More Info Coming Soon!
VA
You probably have the correct RX freq, but not the correct TX freq and tone, and are not activating the repeater.
bpbower88
I do have the correct tx frequency programmed but the pl tone for tx is different then the rx pl tone and I'm not sure where or how to input that for example the channel I need is 155.8350 rx with a pl time tone of 186.2 and 153.9650 tx and a pl tone of 127.3
SteveSimpkin
Lancaster, CA
The following video might be helpful. He discusses setting the encode (transmit) CTCSS tone around 12:30 into the video. From the information you have this would be set to 127.3. Shortly after that he shows how to set the decode (receive) tone. This would be set to 186.2 in your case. Note that the decode tone is optional. You could set it to none (off) and you would simply hear all transmissions on the receive frequency regardless of what tone is being used. This is also the correct setting if the repeater is not sending a tone when transmitting.
ladn
Since you are on a public safety system, remember to set your radio to narrow band deviation on the public safety channels.
You didn't mention which software application you use to program the radio. I've found for my 9800 the RT Systems software is easier to use than CHIRP and far, far, better than the TYT software.
You may also want to experiment with the "emphasis" setting on each channel. I've found (for the systems I use) that checking that box gives clearer, stronger received audio. Your mileage will vary.
bpbower88
Thanks everyone for the replies I will make sure I'm on narrowband and also check out the rt software I was using the one that came with it.
