i am sorry i thought you had a web page my mistake
if you look at this Nifc List from the 2008 fire season they took command 19 from the Fed Interop Pool and they are still using it today in az and in calif that means that when they take a freqs out of Fed Interop Pool they keep it and keep using it they have using command 19 for 5 years now that what it looks like to me
anyway
A communications unit leader on a fire told me the assignments were not permanent. I'm not sure who authored the Wiki page you provided the link to. I noticed the map is pretty old. I don't know how the author got these frequencies. If I knew I might give it more credibility. I think I will add the frequencies to the NIFC radio cache system page I've been working on. I have some frequencies noted as being based on unconfirmed information.
anyway
Clicking on "History" of any wiki will provide the info
Revision history of "U.S. Government (AZ)" - The RadioReference Wiki
Fred, POTUS named part of the Angles ( Eastern San Gabriel Valley) mountains a national monument today. Will freq. change there? Sorry to be off topic
ExSmokey...
Regarding the Los Padres Forest, I notice the morning status report and afternoon weather discussion being broadcast on the Forest Net (LP-2 164.9125) using a tone of 77.0 usually and 77.9 occasionally. Do these tones open all of the forest repeaters so that all areas will hear the broadcast? If not, what description would best be used for these tones?
164.9125 is the input frequency for the Los Padres forest net. A tone os 77.0 or 77.9 does not make any sense. When a signal is marginal a false tone will often be displayed during a tone search. I've experienced receiving those very two tones fluctuating on the screen when I'm picking up a weak transmission. I've also had other tones display when receiving other marginal signals, and they are in the lower frequency range, i.e. below 100.0 I don't know your location and proximity to a base station or Santa Ynez Peak so I can't make an educated guess as to why you are receiving those tones. I'm assuming you are picking up the repeater input frequency from the Santa Ynez Peak remote base station, the Forest Supervisors Office in Goleta or from the dispatch center in Santa Maria. I assume that the input frequency is transmitted from the Santa Ynez Peak remote base station to repeaters, but that might not be true. Repeaters might be linked by microwave and a VHF signal may not be used for keying up repeaters from base stations on the Los Padres. You should be listening to 170.4625 as it is the simplex or channel 1 in this case and the repeater output frequency or channel 2 as well.
Is there any particular reason you are listening to the repeater input instead of the output? All repeater systems where direct or simplex use is allowed the output frequency is used for direct communications and is also used to receive repeaters. There is no reason to monitor the input frequency at all. Unless you are right next to a base station or mobile transmitting to a repeater the output frequency will always be stronger. There are some rare exceptions to that, but I won't explain them as I don't think they apply to you.
Remove 164.9125 from your scanner and you won't have to deal with false tone displays. If my assumptions are off because of where you are located, tell me the general area where you observe them.
Which repeater? They are all supposed to be 103.5 with the exception of Santa Ynez which is 110.9.
I need to make myself clear... I was hearing p.l. 77.0 as the output of the repeater. i do not monitor inputs...buy maybe I should start.
