Hi all,
Thanks for your time. A mate of mine has an issue with his scanner. Its the handheld version UBCD436-PT (Australian Version). He is using a Windows 11 x64 computer.
The problem is that the computer will not recognize his scanner when he plugs it in. He is using the original Uniden supplied cable. It does get seen in programming mode though but what he is trying to do is use Proscan to control the scanner. This can only be done when a virtual com port gets created which would enable the virtual display (To my knowledge).
On the Proscan website the scanner is listed as compatible. I personally own the 536 desktop variant which doesnt use USB but a LPT (com port cable) which I just convert to USB using a store bought converter. He just plugs the USB cables in, turns on the scanner and opens Proscan.
However, when he sets it up in Proscan, nothing shows up in the com port menu. He selected the correct scanner in the menu. I confirmed that.
I tried sifting through the manual to help him out but obviously I am missing something major. Is it not compatible with the virtual display? Are critical drivers missing?
I havent held this scanner in my hand personally and I can only help remotely.
If anyone could give me some information on what I am doing wrong or if what he is trying to do with Proscan just not possible?
Thanks for reading and if you have any questions I`ll make sure to get an answer quickly.
Richad
Richad
