OP25 ubuntu 22.04 - install op25 - Errors while trying to install - target "Python::NumPy" which is not built
BorisG
cmake version 3.10.3
Python 3.10.4
ubuntu-22.04
error after use ./install:
Code:
linux@linux-VirtualBox:~/op25$ sudo ./install.sh
Updating packages list
Hit:1 http://il.archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 http://il.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:3 http://il.archive.ubuntu.com/ubuntu jammy-backports InRelease
Get:4 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
Fetched 110 kB in 1s (153 kB/s)
Reading package lists... Done
Installing for GNURadio 3.7
E: You must put some 'deb-src' URIs in your sources.list
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package python-numpy
E: Unable to locate package python-waitress
E: Unable to locate package python-requests
====== fixing libairspy0 udev rule
====== please reboot before running op25
-- The CXX compiler identification is GNU 11.2.0
-- The C compiler identification is GNU 11.2.0
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
CMake Deprecation Warning at CMakeLists.txt:11 (cmake_policy):
  The OLD behavior for policy CMP0026 will be removed from a future version
  of CMake.
  The cmake-policies(7) manual explains that the OLD behaviors of all
  policies are deprecated and that a policy should be set to OLD only under
  specific short-term circumstances.  Projects should be ported to the NEW
  behavior and not rely on setting a policy to OLD.
-- Build type not specified: defaulting to Release.
-- Boost 1.35 found.
-- Found Boost components:
   filesystem;system
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.2")
-- Checking for module 'cppunit'
--   Found cppunit, version 1.15.1
-- Found CPPUNIT: /usr/lib/x86_64-linux-gnu/libcppunit.so;dl
-- Checking for module 'gnuradio-runtime'
--   Found gnuradio-runtime, version 3.10.1
-- Found GNURADIO_RUNTIME: /usr/lib/x86_64-linux-gnu/libgnuradio-runtime.so
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - found
-- Found Threads: TRUE
-- Checking for module 'gmp'
--   Found gmp, version 6.2.1
-- Found GMP: /usr/lib/x86_64-linux-gnu/libgmpxx.so
-- Using GMP.
-- Found MPLIB: /usr/lib/x86_64-linux-gnu/libgmpxx.so
-- Found Volk: Volk::volk
-- User set python executable /usr/bin/python3
-- Found PythonInterp: /usr/bin/python3 (found version "3.10.4")
-- Found PythonLibs: /usr/lib/x86_64-linux-gnu/libpython3.10.so (found suitable exact version "3.10.4")
CMake Error at /usr/lib/x86_64-linux-gnu/cmake/gnuradio/GrPython.cmake:101 (target_link_libraries):
  Cannot specify link libraries for target "Python::NumPy" which is not built
  by this project.
Call Stack (most recent call first):
  /usr/lib/x86_64-linux-gnu/cmake/gnuradio/GnuradioConfig.cmake:37 (include)
  CMakeLists.txt:127 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/linux/op25/build/CMakeFiles/CMakeOutput.log".
make: *** No targets specified and no makefile found.  Stop.
make: *** No rule to make target 'install'.  Stop.
KA1RBI
Portage Escarpment
OP25 support for ubuntu 22.04 (predicated on support for gnuradio 3.9 and/or gnuradio 3.10) is pending.
Most of the code has already been checked in but there are a few unresolved problems that I hope to correct within 1-3 days- will advise.
Max
boatbod
Talbot Co, MD
Not sure if you're looking to install Osmocom or Boatbod op25, but certainly the latter does not support ubuntu 22.04 or gnuradio-3.10 (which is the version included in 22.04). You may be better off dropping back to 20.04.
BorisG
Which version of Ubuntu is recommended for running op25 without such issues?
krutzy
Culpeper, VA
Boatbod, are there plans to support Ubuntu 22.04 as I am trying to build on a machine that has other purposes?
boatbod
Talbot Co, MD
Someone on github has a repo forked from boatbod that works on 22.04. Offhand I don't remember the name, but it can't be that hard to find.
