I'd like to know the LCN for 453.00000, 453.00625, 453.01250, 460.00000, 460.00625, & 460.01250 - OR - where can I find them?
Remember algebra?
LCN = Offset + (Frequency - Base) / Spacing
The first table reads
Offset = 380
Base = 453.0125
Spacing = 6.25 kHz which also equals 0.00625 Mhz
A base of 453.0125 implies no channels on the system with a lower frequency. Using a few published frequencies from the DB as examples: 453.1 Mhz, 460.1 Mhz and 460.6 Mhz.
For 453.1 Mhz, solving for the LCN is ...
Offset + (453.1000 - Base) / Spacing =
Offset + (453.1000 - 453.0125) / Spacing =
Offset + 0.0875 / 0.00625 =
Offset + 14 =
380 + 14 = 394.
So the channel number of 453.1 Mhz is 394.
The second table reads
Offset = 380
Base = 460.0000
Crunching 460.1 through the same formula (but with the second table) yields 536 + 16 = 552.
Crunching 460.6 through the above formula yields 536 + 96 = 632.
All of this assumes (a) the published band plan is correct and (b) the published frequencies are correct.
