UHF Trunking
lsh1885
Orlando, Florida
I just recently bought a G5 with 400-470 MHZ I am suppose to get it on Friday. I am interested in trying to monitor the trunk system for Kennedy Space Center which is a P25 system at 406 MHZ
APX8000
Sarcastic Member
AES-256 secured
You’ll be good to go. Just keep in mind that the UHF portion of the G5 uses an internal loop antenna vs the external antenna for 7/800. I’ve found for Countywide UHF P25 systems, coverage is limited to within the County borders. Once you start getting to the fringe, you’ll lose coverage quicker than the same 7/800 system in that County. But it will perform very well when you have a signal.
lsh1885
Orlando, Florida
Thanks. I have had a G4 for quite some time but bought a G5 this week. Looking forward to using it this weekend.
