Unable to find Monitor Mode
rogress
Chesapeake, VA
I've got a P25T system setup with two talkgroups in knob 1. Works great. For the life of me, I can't find where to set Monitor Mode on the menu. I go to main menu, Function Status, but I only have 1. Select Zone, 2. Duty On/Off, 3. Bluetooth Settings, 4. Auto Keypad, 5. Fixed Alert, 6. Voice Call.
Is Monitor Mode supposed to be in there somewhere?
(I'm trying to monitor all talkgroups, not just the 2 have programmed)
ecarvalho
Press F.Sts. It's the last option
rogress
Chesapeake, VA
Something in the way this knob is programmed must be manipulating what shows up in Function Status. One of you said Monitor Mode was the 4th item (4th is Auto Keypad for me). The other reply shows it as the 5th item. 5th is "Fixed Alert" for me. None of the options under Function Status are Monitor Mode. Does this trunking system need to be programmed a certain way?
Currently I'm on the knob selection that has two talk groups, which are working.
Geneo516
G4 monitor mode
Hello all I've been having the same problem with monitor mode being greyed out. I've went under the pager configure and monitor mode is checked any ideas on what I can do to get this to work thanks.
tdeater
Fremont, MI
For the person with monitor mode greyed out, the latest firmware on the pager removed the monitor mode toggle functionality from the menu (but it still shows there greyed out). You now have to define a knob position for talkgroup monitor vs talkgroup scan. (I don't remember if that is exactly what it says, but it's something like that) Scan will listen to whatever talkgroups you put in the list on the knob, monitor does what the monitor mode did before. *Disclaimer, this is all from memory without having the software in front of me, but should point you in the right way. :)
JASII
Memory Capacity
Monitor Mode Greyed Out
I did the Firmware Update to V1.10 and the Monitor Mode is greyed out. Does anybody happen to know if that will return with a future update?
JD21960
ILL-annoyed
Mine is grayed out too. But I simply made sure to enter a wildcard in step 4 of the PPS by adding 65535 as a Talk-group. I have several Control channels set up for different counties and can hear ALL traffic that way. Named the Zone MONITOR MODE so it acts just like the mode grayed out. My guess is they'll enable it again.
