Unable to read Harris XG75p
Mogley
I got a 75P. Tried to read it and RPM doesn't seem to see the radio at all.
It's an XG75p USB programming cable. Nothings showing up. The cable shows up as com3 on my PC.
Is there some type of programming mode or something else I'm missing?
K2NEC
5F6
Did you confirm the comm port in RPM?
Mogley
That's the problem I get some type of JavaScript error trying to select com port.
"QueryDosDevice() failed with error 122: The data area passed to a system call is too small."
buddrousa
What version firmware is in the radio?
What version is your software?
Did the Software come from a Factory Dealer?
IS the Programming Cable a Factory Cable or a quality clone?
Mogley
After digging around on this website, found an old link to weird windows dotnet errors and found this.
Doing this worked by changing my comport to 3.
"If you are a tinkerer, you can change the COM port number in the config file (C:\ProgramData\Harris\RPM\RadPersMgr.xml) and then open RPM. Just don't touch the COM port selection button and the software will communicate just fine with the port defined."
