Unblocked 8200 MkIII W inverter cards
richb6
I see these on EBAY occasionally, do these inverter cards make it possible to hear anything or are they old technology that doesnt work?
Neal
Memphis TN
8200
The AOR8200 will not receive digital signals and will not trunk track.
The inversion card is an inverted speech descrambler. This is seldom used and is illegal to listen to.
It is really a great radio for conventional use and milair.
Sac916
Voice inversion is still used, but it's rare.
In Northern California the State Department of Justice (DOJ) uses voice inversion and I've found one (small) law enforcement agency that uses it on occasion.
I've also heard a couple taxi cab companies using the inversion.
I've got the card for my 8200, and it works very well.
The only two setbacks about the card is;
1. It doesn't detect the setting ( IE it doesnt scan the voice inversion variables )
2. It's either on/off. It doesn't activate by itself. If you come across an inverted signal, then you must "turn on" your card.
I've also come across some voice inversion programs online.
freqhunter
Somewhere in Time....
Inversion
Inversion is used a lot in the Cleveland area. There are 3 departments in the area that use it frequently. One county agency that uses it all the time. And two agencies that use it on their Tac frequencies. I have no experience with the VI8200 so I am unsure how well it works.
