Unication G1 programming question
fireman_dude
Jersey Shore
Just purchased a G1 and self programmed. Just figured out the timing for the voice storage to work correctly. Now I am having an audio issue. On selective call after the 2nd tone the pager alerts as normal and then there is dead silence. I get no audio message. After the voice timer ends I can play back the message but the initial message after the alert is not heard. Can anyone help me ?
w2lie
New York DB Admin
Long Island, NY
Change your settings to Delay N Auto
Set your delay timer. This is the amount of time the pager records after the first drop in carrier.
Then set your record delay timer. This is a looping timer that keeps the recording going after each additional drop in carrier.
fireman_dude
Jersey Shore
The problem is not with the delay timer. The voice storage is working fine. The problem I am having is after the alert (tone B) I get no audio from the speaker. The message is only recorded internally. I tried disabling the "Push to listen" feature to see if that fixes it.
kearthfan101
I have a feeling it's push to listen that's causing the issue...
I'll have a look to make sure.
