Unication G5 audio vs SDS-100
ve52001
Duncanville, TX
Yeah I might eventually get both. But just being around the metroplex I might go with the G5 based on the compact size and ruggedness. I first was thinking of getting a APX900 and do the NAS scan but messing with the Motorola stuff can be a pain. I used to program two way radios back in the days when I was a volunteer fireman, but it was much simpler back then. We just had a repeater and it was analog.
Solidjake
NYC
@ve52001 Let us know how it goes and why you decided to go with one over the other after you finalize the scanner. Enjoy
picscan
CA
Dropping both on the ground the G5 will win and sounds better to me, plus it has bluetooth so you can wear an earbud or two if ambient noise is too loud. SDS does more but battery life isn't great, my G5 goes about 15-16 hours.
Solidjake
NYC
I have to keep track of my G5's time. 3hrs a day four times a week on a charge for sure. I'm sure it's around 16 or so maybe 18
Forts
Ontario, Canada
I've had my G5 for maybe a year and a half... give or take. Since then I could likely count on 1 hand where I've used my SDS over the G5.
G5 is..
- compact and discreet
- far better battery life
- can easily connect a BT earbud for even more discreet listening
- excellent audio quality
- surprisingly sensitive for such a small/built in antenna
- supports encryption (if you can utilize that)
SDS is..
- more flexible in listening options (freq range/digital modes etc)
- program on the fly
- displays more info
- using while connected to a GPS can't be beat while travelling. Easily my fav feature of the SDS
Just some observations off the top of my head.
blackbelter
G5:
- Clear audio with no distortion. Stronger audio with an amp charger and or a Noxgear 39g in my car ( Your system,'s audio may wary). Automatically Connects to my AirPods Pro.
- Form factor. Small enough to be easily carried.
- Built like a tank.
- Never misses a key up on my targeted systems. Compare to my SDS 200.
- Requires little interaction with the device after the initial set up ( other than changing zones and or volume level).
- Hold or ignore Talk groups.
- Awesome support from Ray ( Dealer ).
- As mentioned before 12 or more hours on a single battery charge.
- Professional grade device.
- 2 years of warranty.
ve52001
Duncanville, TX
Well I decided to go with the Unication G5 today and ordered a Motorola 800Mhz stubby antenna, screen protector, and drop charger. I will get a SDS100 in the future, but for now, I like the fact how small this unit is, more rugged, and will be easy to carry in and out of my truck for around the DFW metroplex. I will carry it on the go to and from work. If anyone was curious I ordered the pager from Ray's Pager, after reading good reviews in this forum. Thank you all for your inputs and I'm sure I will enjoy my new toy. Right now my local PD and FD is on NXDN and I use my TRX-2 to monitor them, but they are eventually are going to the Dallas P25 trunking system, and even if the PD goes encryption, hopefully the FD stays in the clear. 73's KE5NPN.
belvdr
No longer interested in living
Interested in how the Motorola antenna works compared to the stock. The stock antenna is very good already.
mitbr
Tampa Bay Florida
Ray is great!!! I used him to buy my G4 and G5. I would suggest NOT using the Motorola ant, some people have reported problems with that ant pulling the pin out on the Unication, use the ant that comes with it it will work just as well and has a small form factor.
Tim:cool:
ve52001
Duncanville, TX
Well my pager is due in today. I am stoked on getting it programmed to check it out. When playing around in PPS, I didn't realize how my zones you can use. For the initial first time flashing, I'm only using one to get use to everything. I am scared on trying the Motorola antenna, after everything I read about it. I will continue to use my TRX-2 to monitor my local PD & FD, which are for now on NXDN trunking, but will eventually transition to the local simulcast P25 system.
IAmSixNine
Dallas, TX
Welcome to the Gx club. I have several G4 and an SDS100. The more you monitor the more you miss so nothing wrong with starting out on a G4 then in the near future an SDS100.
Also you will want to program in the 3-1 layer which is what your agency will likely be using.
blackbelter
Although I realize that every monitoring QTH is different, My G5's strong and compact supplied antenna has been more than sufficient to capture the monitoring systems. This also includes using the device inside my house and or cars. In event that I would need to capture a stronger key ups, I would use my amp charger with an old RS antenna to gain an additional bar or two on our 700/800 systems as well as a DMR station. I am aware that the primary function of the amp chargers antenna might be UHF/VHF.
