Unication G5 Fire Alerting Burlington County NJ
dave461
Anyone using a Unication G5 in or around Burlington County NJ and have it successfully alert on fire tone outs? If so, are you willing to share your pps file as a guide for me to get started?
dave461
I wasn’t aware that the p25 patch was able to do tone outs. I tried setting up for the analog and can’t seem to get it to work. My minitor 6 works fine.
dave461
Analog tone outs or via the P25 digital patch?
Sorry for the odd posting, my iPad spazzed out. I wasn’t aware that tone outs were working on the P25 patch. In either case, my minitor 6 works fine but I can’t seem to get the g5 to trip on any tone on analog. I’d be interested in using the P25 but have absolutely no clue on setting that up (hence a sample pps file for reference)
dave461
Update: I imported from my Minitor 6 into a new profile that I sent to the G5. Still not getting any alerts on tone outs on the G5. The Minitor alerts fine. I checked the tones and verified that they are correct. I know it's something stupid that I'm missing. I'm on firmware 2.02.
crazyboy
NJ
They’re pagers, of course people have successfully used them for paging on analog. Either post your configuration file, screenshots of the relevant pages in the PPS, or contact your dealer especially if it is for department use.
dave461
Here's the configuration file. Any help?
  • GxPPS_V0.4.0.41 _Fire Voice Paging_240928.zip
X9009X
Burlington, NJ
Dave,
Start with the protocol timing. It needs to be 2000ms and 2000ms for A & B tones. Factory default is 1000ms and 3000ms.
Second the paging over P25 works when the County Dispatchers have the patch enabled on the console.
Feel free to message me Ill help you. I have numerous users in the county with no issues.
crazyboy
NJ
Your protocol timings are definitely wrong. Multiple settings in there. Start with the default and adjust only the timings that are required by your agency.
dave461
Ok, got the paging to work. Definitely was the timing. Is there any specific setting for the Binding feature or is AutoReset the way to go for the reset mode? I currently have it set to AutoReset.
crazyboy
NJ
The reset mode depends how you want it to function after the page. I would suggest reviewing the different options in the help file and see what fits your desired operation. I typically do not do auto reset, and do one of the manual reset modes so update announcements over the paging channel are heard while responding and then manually reset after the call.
X9009X
Burlington, NJ
I agree with the statement not to use auto reset in Burlington County. Use manual reset. If your part of a task force assignment and your tones are one of the first to be dispatched by the time the voice is sent out for the call you may be at the threshold of time.
dave461
Thanks for the assistance. I believe I have everything working now.
dave461
