Unication Help!
M
MITTY
Guest
After doing the firmware upgrade I (and at least one other poster)have lost the ability to decode QC over P25 Phase 2. I have 8 systems that were working fine before. I also have one system that I can't get to mute until the tones come across whose setting mirror the other 8. It stays and monitor and won't mute. Any help would be greatly appreciated. Thanks.
hfd26
My issue since the update is that I dont get any 2 tone over p25 like I was before. Could someone explain better what the p25 sub-group id (digital address)column is and what should we put there
TexasMale
Port Neches, Texas
I had re delete the new pps software and re-install to be able to make it work. They need better bata testers
guyiv
Lower Delmarva
I have the same problem. I used a CP that a friend had and it worked but mine will not work or any I create.
hfd26
I ended up going back to the old firmware (1.1) and the older pps. Now I just waiting for a call to happen and see if it work again.
guyiv
Lower Delmarva
I made some changes that they had in their CP so I am seeing if that fixed it but no call yet. I had been thinking I was just going vibrate insensitive from the pager. Since I only use vibrate.
hfd26
So I went back to the old firmware and pps and now my pager is activating 2 tone over p25 again. My pager doesn't like something they changed in the new firmware so the old one I'll be on till something gets fixed. Kinda sucks that I don't get to enjoy some of the other fixes they made
guyiv
Lower Delmarva
I have finally figured out the problem! It only took me 5 hours, I had to wait for calls to test out multiple vairables to make sure I told everyone the correct thing.
Like it has been the Alert mode needs to be set to "Tone", but now Alert Tone needs to be set to anything besides "None". Like The Alert Mode the Alert Tone does not change what Alert Tone is played.
hfd26
I had mine set to chirp and still got no tones over p25
guyiv
Lower Delmarva
May be it has to be defult I have not tried any of the others.
markjrenna
NJ
I've also seen Push to Listen go to Yes. Should be No for monitoring.
