Unication pager stun
DeoVindice
P25 Underground
5150 Level
I thought Page/CA was a bi-directional process on P25. I know it is on trunking as it's control channel data.
It's bidirectional/confirmed data on conventional as well. If I remember correctly, the Unication requires a radio with the same ID to be active on the system to correctly decode a call alert, but I may be wrong there.
RRR
OFFLINE
USA
If a unication is disabled by "stun", how is it re-enabled? PPS?
GTR8000
NY/NJ Database Guy
BEE00
They are uninhibited the same exact way a subscriber would be, by sending the uninhibit command over the control channel.
Unitrunker2
Makes perfect sense to me, especially since they have encryption capabilities. Unication with proper keys gets lost? No problem, just inhibit it. Only drawback is the system can't tell if it's been inhibited since they are RX only.
Does these pagers support OTAR?
CanesFan95
Was Homeboys-Scanna
Banned
FL
And there's no other way? Not even if you ship it back to Unication?
  • Like
Reactions: RRR
RRR
OFFLINE
USA
I would think PPS could re-write an inhibited one, if not, Unication surely could.
It has to be able to react to an inhibit command before it can be inhibited. A scanner won't react to an inhibit, unless something has been added to the firmware.
