Unication pagers
n1chu
Farmington, Connecticut
Wondering if anyone with experience with the Unication pagers can advise;
I’m thinking about pulling the trigger on a Unication pager but I have concerns… it’s expensive, I don’t want to buy one only to learn the agencies you want to monitor change systems or modes or encrypt a year later and you get to repurpose your Unication page to a door wedge. I would like to monitor both PD & FD in Farmington. 855.2375MHz & 154.19MHz respectively. Any input is appreciated.
smartconnect
astro25 v7.17
stuck in a gtr ess
Send it! You will need the Dual Band G5, and you will definitely be impressed.
Afaik Farmington is not upgrading anytime soon. And if they do, it is highly unlikely the Fire department will go enc. And you will always have systems like CLMRN and West Hartford too…
nhfdcadet
CETsr
New Hartford, Ct
You could monitor both of those with a G5, but who knows if they'll ever end up encrypted or not
n1chu
Exactly. The agency could upgrade to another mode, frequency band, encrypt, etc. Just fishing for any u do that might indicate a change is in the wind…
jgorman21
Glenmont N.Y.
They are superior receivers. Professional grade performance. You can never know what an agency will do as far as encryption.
You will not be able to monitor both at the same time, they will need to be on separate knob positions, unless those are both conventional frequencies, which it looks like they are. But, as others have said, quality is excellent. I spend more time using my G5 than my scanner.
nhfdcadet
CETsr
New Hartford, Ct
I personally haven't heard of any intent for change. You'll be able to scan between the channels fine, only thing it won't scan is conventional and trunked at the same time , or two trunked systems simultaneously
n1chu
What gives you the impression the FD would encrypt if there was an upgrade?
n1chu
To Smartconnect; Sorry, I miss-read your post to mean it was highly likely, not highly unlikely encryption. .
To all;
Thanks for the info. As for the number of times encryption was mentioned in this thread… it’s not a consideration when purchasing. So it does not need to be mentioned going forward.
nhfdcadet
CETsr
New Hartford, Ct
To all;
even if they did end up going that route, if you sweet talk the right people, they may be willing to load the key into your pager.
Firebuff66
CT
You can never tell what a department is going to do.
I don't listen to much police so Fire departments going to the CLMRN are a win for me as I can get them much better and further away then when they were conventional.
I have 3 G5s and they work great, all of them have over 40 zones in them, they do have some limitations but they are pagers not scanners
Ryanwoods78
I got a unication g1 pager and it's programmed but I can't hear tones drop can someone help me with this this is first g1 I ever owned I would rather have Motorola again my email is ryanwoods7879@gmail.com email me if you can help me
