Unication PPS RR Import
Acox565
I am currently trying to update some frequencies into the new Unication PPS (version 4), and no longer see the radio reference import button on the top of the screen. Have they done away with this, with the only option being using a .cvs file to upload frequencies from RR? I wasn’t sure if I was missing it somewhere or if they have done away with the button. If they have done away with it, it is no where near as easy to import as when they had the button in PPS version 3. Please correct me if I am missing the old input style of selecting state, county, system, etc somewhere in the PPS IMG_9004.jpeg
N6ML
Pretty sure you need to have a Radioreference premium subscription to access this feature...
AFAIK you can do an offline import from RR without a subscription (PPS comes with a snapshot of the database), but you need an account to get updates.
Even if you did have to have an account, there would have to be a place to enter your credentials to access it.
The "Import Radio Reference" button should be at the top-right corner of the PPS main window - to the right of the "Customer Support" information. Can't tell from the OP's screenshot whether it's there or not. Maybe it's off the edge of the screen? Low-resolution laptop or something?
kruser
Well Known Member
W St Louis Cnty, MO
The RR Import button is definitely there in the latest PPS versions.
As @N6ML said, it's just right of the Customer Support info at the top of the PPS window.
Acox565
Oh ok, it must just be getting cut off with my laptop screen then. That makes sense, I was wondering why I wasn’t seeing it in the new update. Thanks a lot everyone !
