jeffmulter
I hope a couple of you can give me suggestions for problem-solving a digital decode problem for another hobbyist.
He's trying to monitor some digital talkgroups on the Salisbury, Winston-Salem and Greensboro systems when he's in those areas "working."
He uses both a 296 and 796, and both are having the same problem ... which makes me think it's a programmable setting for the scanners. Both scanners will display the correct digital TG I-Ds, but he only hears the communications as raw data.
He's not getting an digital card warning messages on the display. He has tried adjusting the digital audio setting.
Analog talkgroups are received fine, as are conventional channels. He can confirm the talkgroups he is trying to monitor are not encrypted.
I don't know how recently he acquired the scanners, and what firmware version is in them, but it does not appear that the firmware upgrade Uniden has available on their website would impact monitoring the N.C. systems mentioned above.
I'm open to suggestions.
Thanks,
Jeff
Thanks,
Jeff
