Uniden 885 Antenna question
DOAUSMC0331
Hi all,
Wasn't sure where to post this as it's a hybrid unit. I am trying to figure out which antenna my weather stations receive on? Is it the CB antenna or the scanner antenna? Any help would be appreciated.
JAKE
WSGB713
n1chu
Farmington, Connecticut
You are getting the weather on your Scanner antenna. CB antennas are resonate at 27 MHz. Since the Weather frequencies are 162 MHz it has to be your scanner antenna.
DOAUSMC0331
I'm curious would other cb's with weather have a built in antenna for weather stations or how does that work?
They usually use the CB antenna.
Works OK, but like mentioned above, a CB antenna is resonate at 27MHz. NOAA weather radio is 162MHz. The non-resonate antenna works OK, but a proper VHF antenna would work better (but suck for CB use…)
DOAUSMC0331
That is the thing the 885 has a scanner and a cb both on their own antenna. That's why I'm trying to figure it out.
OK.
n1chu covered it above. On that specific radio that has a scanner and a CB in the same box, the NOAA weather radio uses the scanner antenna. The CB uses the CB antenna.
On the radios that do NOT have a built in scanner, just the NOAA weather channels, it uses the CB antenna. Not perfect, but falls into that "good enough" category that pleases most consumers.
DOAUSMC0331
Awesome,
I really appreciate it. I just wasn't sure how they would have it set up but that would make sense.
Thanks for the reply
DOAUSMC0331
Incase anyone wants to know or even care the uniden 885 recieves it's NOAA broadcast from the CB antenna not the scanner antenna. Reached out to Uniden and that's what they told me.
rjdj2000
Gone Cuckoo
Central NY
Well idk why they told you that as it doesn't. I have one in my truck, using the stock wire on the scanner side and NO antenna on CB side and I get weather just fine. If it came through on the CB antenna, without one hooked up, I wouldn't get it. (I just have a dummy load on the CB side in case mic got bumped)
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
You could simply remove one antenna at a time and prove or disprove it yourself you know.
