Title says it all, I am clearly on the interne Uniden BC125AT / BC_VUP / Internet Access Failed
S SCJ6771 Member Joined Jun 12, 2023 Messages 7 Jun 12, 2023 #1 Title says it all, I am clearly on the interne Uniden BC125AT / BC_VUP / Internet Access Failed
mass-man trying to retire... Premium Subscriber Joined Mar 15, 2004 Messages 1,945 Location Parker Co., TX Jun 12, 2023 #2 worked here...what version is in your 125AT? You might delete the current BC_VUP and download it again.
J jaspence Member Premium Subscriber Joined Mar 21, 2008 Messages 3,041 Location Michigan Jun 12, 2023 #3 Have you read this page? http://info.uniden.com/twiki/bin/view/UnidenMan4/BC125ATFirmwareUpdate There have been no functional updates to this scanner in the years I have owned it. Last edited: Jun 12, 2023
S SCJ6771 Member Joined Jun 12, 2023 Messages 7 Jun 12, 2023 #4 mass-man said: worked here...what version is in your 125AT? You might delete the current BC_VUP and download it again. Click to expand... Version 1.04.02, I removed and reinstalled many times.
S SCJ6771 Member Joined Jun 12, 2023 Messages 7 Jun 12, 2023 #5 jaspence said: What software are you using? What operating system are you running on the computer? Are you doing this to program the radio? Click to expand... Windows 11, just trying to update firmware
J jaspence Member Premium Subscriber Joined Mar 21, 2008 Messages 3,041 Location Michigan Jun 12, 2023 #6 Why have you removed and reinstalled it? Most manufacturers suggest avoiding an install unless it is to fix a known problem or add features to the radio. This is an older scanner and USB drivers from before Windows 11 do not often work with Win 11. Last edited: Jun 12, 2023
Icanhearit Member Joined Dec 6, 2021 Messages 129 Location Bay Area, CA Jun 12, 2023 #7 tried on windows 11, no problem. check if you have any windows firewall rules blocking you. Also I hope the BC_VUP does not suffer from using ftp over tmobile ISP issue (as Sentinel DB update does).
