when driving, it seems the faster you go to the more static comes on the scanner when there is a transmission.
Drive slower? j/k
Is there anyway for the static to not be there, as if I was home and it’s perfectly clear.
Ok, so you're getting static in your car. It could be a myriad of things, it'll be on you to find the source.
What kind of car (and engine?)
LED headlights?
Aftermarket LED autozone-grade auxiliary/fog lamps?
Plug in cellphone charger/USB power supply?
Does the static go away when the radio is on, and the car is completely off?
Is the static there when the car is on, at idle?
Does the static change when the vehicle is in park, but not at idle? (increase with engine RPM?)
Does it increase in gear, and moving (wheel speed dependant?)
What is the power source?
What antenna?
These are just some of the questions you will have to do a little bit of legwork on, so that the hive-mind can try to figure it out.
