BCD160DN/BCD260DN: Uniden BCD160DN, air band issue
NS9710
Niagara Falls, NY
When I get traffic on the frequency 118.500 (tower frequency for IAG airport, shared with a military base.
The scanner stays “stuck” on the frequency once traffic has been detected, the only way I can get the issue to clear is by “SCAN” button, or by turning on the Attenuator.
I am using the Smiley Slim Duck 5/8 160MHz antenna currently, issue also persists when using the stock antenna as well.
It happens no matter where I am, I could be in a field, in a car, in the house, doesn’t matter where.
Any idea of what’s causing this issue?
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
Ubbe
Stockholm, Sweden
If you get that at every location then it must be a spurious signal generated inside the scanner. Only solution would be to set the suggested IFX setting to that frequency.
Open squelch fully and listen to the noise and then switch to another frequency like 118.575 and listen if the noise level changes. You can also program those two channels to FM or NFM as it might be easier to hear if there is a signal interference on 118.500
/Ubbe
wtp
Port Charlotte FL
set up a custom search of 118 to 119,
take the antenna off,
search.
it might be a birdie that is close to 118.5
if it finds one, i would then use a frequency on the other side of 118.5
the antenna out thing is also useful to find really close transmitters.
Ubbe
Stockholm, Sweden
A spurious signal generated from its own electronics, that happened to the BCD436 when Uniden removed a filtering capacitor from the clock line, can radiate to the outside and be picked up by the antenna. If using coax and an antenna further away the signal became so weak that it didn't interfere.
/Ubbe
NS9710
Niagara Falls, NY
This sounds like it may be the case, because as I said, I never had this “lock” in the signal until AFTER a transmission was picked up, then I had to force a scan continue before it dropped the interference.
/Ubbe
NS9710
Niagara Falls, NY
I pull the antenna off the scanner when locked into the the static and it clears the “hang”, should I use Attenuator or IFX, and if so, which would be better off?
kc2asb
NYC Area
I think some experimentation is in order here. You already know the attenuator eliminates the "hang" issue. Try IFX and see if it still hangs on that frequency after traffic is received.
I prefer to use the attenuator as an absolute last resort, because it will (obviously) affect reception of weaker signals. Can you still hear the Tower with the attenuator on?
NS9710
Niagara Falls, NY
I can still hear everything with Attenuator on.
kc2asb
NYC Area
OK, great! However, I would still try the IFX and see what the results are. If it doesn't work, then the attenuator is clearly the solution. As I said, I prefer not to use the attenuator unless absolutely necessary.
