mrkaye
Can anyone help me with programming a BCD396XT for Harford County, Maryland, for Sheriff, EMS, State Police & Medevac? I'm confused by a couple of things and believe I'm not scanning everything I want to scan.
Are you programming by hand via the keypad or using software? I recommend getting a copy of FreeScan. I've used it to help others program 396XT and 346 units
https://sites.google.com/site/sixspotsoftware//products/freescan
Here is a file for Harford Cty, Md. Its a Freescan file, zipped per RR requirements. Win Zip or 7 zip arfe programs that are used for unzipping. Maryland State Police are TDMA so they are out for the 396xt. Still you have plenty to listen too.
AFAIK MSP Waterloo (near Jessup) is still just on low band, and not on FiRST as yet. Not all barracks have moved...
Anyway, this article from our wiki contains links to everything you will need to know to understand how to program these scanners. The links for trunking and the Easier to Read manual (at the bottom) are 2 good places to start.
Program your DMA Scanner - The RadioReference Wiki
Mike
A friend purchased a BCD325P2. I told him I could program it, as I did with my BCD396XT with Freescan. So far, I have tried everything I know, but cannot get the computer to recognize the scanner. I have downloaded the drivers, rebooted several times, and still no luck. It just says that it can't find the port that I'm connected to.I can't believe Uniden makes it this difficult. Anyone provide some guidance?
Thanks so much! Yep, I'm an old computer hack. My problem is still getting the computer to even see the scanner. I've changed ports multiple times, but it sounds like the 325 interface is not ready for prime time?The newest version (2.18) of Freescan supports the 325P2 / 996P2 *experimentally.* I've gotten it to work with my 996P2, but occasionally it "makes mistakes" and I need to reload the programming. I'm going to assume you know how to use FreeScan to find available serial ports.
No 'key-press' required, since the 325P2 does not have the SD card where 'mass storage' mode is required.No, I wouldn't say that - it's actually the Freescan software that's the problem in that it's not always reliable. Have you confirmed that your version of Freescan is 2.18? It does work with the 996P2, so it *should* work with the 325P2 as well. There are more expensive 3rd party software that works with the 325P2 / 996P2 that seem to do a better job. Anyway, I'd triple check that a Uniden serial port exists on your computer when you plug in the scanner to the computer (using Device Manager.) If you don't see a port created when you plug in the scanner, then the problem is the computer. I'm not sure if the 325 requires any keypresses to tell it to use a serial port vs. mass storage - my 996P2 does not. These are just some suggestions you can try...
Easier to Read BCD396XT Digital Scanner Manual
That should help you figure out your scanner. Have fun.
