rbritton1201
Captain1201
- Joined
- Jul 27, 2020
- Messages
- 407
It's widely represented that the Uniden BCD436HP can not be monitored while charging the batteries. But, if using the "serial" selection when plugged in for charging, the scanner can be monitored, but it will not simultaneously charge the batteries at the same time that the scanner is being monitored. I speculate that the amp rating of the charger at 1 amp isn't sufficient to charge the batteries in the scanner while also monitoring the scanner.
I speculate that the BCD436HP can also be monitored when plugged into a vehicle's cigarette lighter, with or without batteries installed, provided the cigarette lighter adapter is a 5 volt-1amp DC cigarette lighter plug. I plan to experiment with respect to my theory, provided someone doesn't point out a glaring flaw in my theory. I am able to listen to the BCD436HP if I do not select "charging," but select the "serial" function when I plug in the charger by pressing the "period+no" button, but there doesn't seem to be enough amperage to charge the batteries while simultaneously monitoring the scanner through the serial connection.
These 5V-1amp plug-in cigarette lighter chargers aren't typically available in the USA, most of them available in the USA are 12Volts DC, and they have excessive amp ratings. But, the 5v-1amp, as well as 2-3amp, cigarette lighter adapters are readily available through Aliexpress (China), and for a very affordable price, a couple bucks. I purchased several different ones from Aliexpress, and I'm awaiting delivery at this time. I purchased several because Chinese quality varies, and due to the several weeks required for delivery, I did not want to have to wait for delivery of others if some of what I receive from the first order end up being of questionable quality, which is typical of some Chinese products. I like having several to choose from...
My plan is to keep Panasonic Enoloop batteries, which are very high quality batteries, in the BCD436HP and keep them fully charged, for times when I'm without either AC to DC 5v.1amp wall charger or a vehicular 5 volt DC-1Amp charger through the cigarette lighter. Most of the time, I will monitor the scanner via a 5Volt 2-3 amp charger, or via the cigarette lighter using a 5Volt 2-3 amp cigarette lighter charger when mobile.
I speculate that chargers that supply more than 1amp charging capability, perhaps 2-3 amps, might charge the batteries while the scanner is on and being monitored. The AC to DC 5Volt 1Amp wall charger doesn't seem to have enough amperage to charge the batteries while also monitoring the scanner. But, using an 5volt-1amp AC to DC wall charger rated at 5V 2-3 amps, or cigarette lighter charger 5v. 2-3 amp, a slightly higher amp rating, might be sufficient to monitor the scanner while also charging the batteries.
A realize that the charger with a amp rating higher than 1amp might be detrimental though, because by using a charger that delivers 2-3 amps, for example, it may result in also my running the risk of reducing the life of the batteries, and/or creating too much heat. But, the scanner does have circuitry that shuts down the scanner if heat rises beyond Uniden's recommended level. So, a higher amp rating charger is something that needs to be experimented with to make sure the additional amperage isn't detrimental. But, if a higher amp rating works without any detrimental effects, the charger may permit you to monitor the scanner, while also charging the batteries, if you select the "serial port" selection rather than the "charging" selection with either an AC to DC 5V 2-3 amp wall charger or DC 5v 2-3 amp cigarette light charger plugged into the scanner while mobile.
