cdoyle7723
- Joined
- Jun 19, 2019
- Messages
- 8
Looking for simple options for an outdoor antenna for the Uniden Bearcat BCD996P2. Does not need to reach that far, just a simple antenna nothing big or complex. Thoughts?
I use a Discone on my chimney.simple options for an outdoor antenna for the Uniden Bearcat BCD996P2.
Just local. Jefferson County in Kentucky.What frequencies do you plan to monitor?
Good choice!!D130NJ Diamond Super Discone Antenna
Sorry I'm new at this. If you go to radio reference and look up Kentucky, Jefferson Co. That should tell you the frequencies. I know there are some trunked bands here as well but I'm not sure what to answer on the exact frequencies. I'm just getting started so I know I'll make some mistakes.If the signals you are wanting to receive are strong and nearby that will work just fine.
I asked what specific frequencies you were wanting to monitor previously because if they are all within a small range you would probably get better results from a band specific antenna, or possibly even a yagi if they were all coming from the same direction. But since we still don't know the frequencies you are planning to monitor, we couldn't make a suggestion in that regard.
Now that you have an antenna ordered, you are going to need good quality coax with the correct ends. I suggest making careful measurements of exactly how much you will need and ordering a custom made cable in the proper length/s. Again, knowing the specific frequencies you want or will plan on monitoring will help in suggesting the type of coax to get.
You also need to make sure you waterproof any connections that will be outside, properly ground the antenna/mast, and I would also suggest some kind of surge protector such as a polyphaser.
Thanks. I'll plan accordingly.Height above obstructions is even more important. Get it out away from trees, power lines (stay FAR away from these), other homes, etc and that will increase your range considerably. And don't use cheap RG58U- as the frequency goes up, so does the loss when using a long length. RG6 or 9913 is better...Mike
The Louisville Metro Safe system is an 800MHz trunked system. Unfortunately, the main Jefferson County site is simulcast. See the link to the map of sites here.Jefferson County, Kentucky (KY) Scanner Frequencies and Radio Frequency Reference
Scanner Frequencies and Radio Frequency Reference for Jefferson County, Kentucky (KY)www.radioreference.com
So it looks like everything is between 150-160 and 450-470, myself I probably would have went with a dual band vertical, but the discone will work just fine as well and will give you more receive options if things change.
How long is your coax run going to be?
The main users of Uhf appears to be the hospitals, with some EMS dispatch also on Uhf. Three of the four EMS dispatch on Uhf are DMR. There a few school related channels on Uhf as well. There are also a number of EMS talkgroups on the trunked system, but they show to be encrypted.
