There are no channels for close call. Usually, the default setting is to scan all bands, but could tell it to skip 800, for example, if you know there are no 800mHz systems in the area. When it finds some signal, it will save the frequency in a system called close call, and it will do this for as many different signals as it finds. There are many other options for notification, depending your model.how many channels can you setup for close call
Close Call does not do that. However, your model also has priority, and it works the same basic way as your radio shack. Read the manual on Priorityi have a bc355n this is my first uniden i have some radioshack models that has priority channels i like to set fire & ems channels to scan more than the police i didn't know if close call does that
i have seen where it has close call priority is that it
Neither can I. I searched the online manual for Priority, and all I found was CC. I have never heard of ANY Uniden without channel priority, so maybe UPman will clarifyi can't seem to find that in the manual
No. As we have all said, they are totally different.do you think they have changed it to close call priority on the bc355n model
