Hi all,
I have a Uniden PRO500D CB radio I picked up for a real steal. I turned it on and there is no sound on receive, no matter the antenna connection, no matter the mic connection. I've checked all possible solutions (Is the mic plugged in? Is the antenna plugged in? etc...) and nothing. I've also noticed that the nearby 7808 regulator gets STUPID HOT on TX and refuses to cool down. This radio uses the long defunct TDA1905 audio amp chip. Everything else is fine - channel displays light up, radio keys, S meter lights work...but no audio
The radio dead keys at 4 watts solid, so no issues with the driver or final. However, even if I try talking, I can't get any modulation out of it in addition to the lack of RX. So no TX or RX audio is coming to or from this radio period. One other thing I checked was the speaker, and it too tested okay.
In doing some testing, I found that the output pin on the TDA1905 is indeed shorted to ground. I suspect that this is the issue but I wanted to see if my gut feeling was right.
Am I correct to assume that the chip has gone bad or is there another variable afoot here such as the electrolytic caps? Visually I didn't see anything wrong with the capacitors - they all looked fine to me, no bulging, no brown goo/corrosion, etc., and PCB traces are on par too.
For reference, I've included the schematic here:
Let me know what you all think and if there's any other troubleshooting I should do! Thanks!
