Union County NJ
Scut
Pocono Lake,PA
I have my pro-94 programmed for the Union Co system ,put in the talkgroups I wanted etc..
I have the freqs in order as listed in the Union Co forum,but get NOTHING in trunk mode if I disable trunk and hit scan I hear them talking
:oops: What step am I missing ? ?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
A link to your county's freq. is here :
http://www.radioreference.com/modules.php?name=TRSDB&sid=652
First of all ,you are in EDACS trunk mode, correct ? Is there an E on your display ?
Next, what position have you programmed the site freq's in the bank ?
You should be starting at ch. 1 or 101 or 201 etc... in other words the
first channel in the selected bank. You should see this - - - - -
if you are receiving the control channel while in SEARCH mode. The talk groups should appear as activity is detected.
Give that a try and see if things turn around for you.
Good luck
Scut
Pocono Lake,PA
The freqs were in logical order but not first in the bank.However,
I put them in first channel of the bank and that did the trick!
I have motorola trunk in other banks and they worked witout being started in the first channel of the bank so I assumed............
I re read the directions and didn't find that tip.I am grateful for your help I have Port Authority in there and it worked fine , but it was programmed the way you directed prior.
Thanks Again,
George
