Union County question
Medic8185
Charlotte,NC
I just moved to Union County from Pineville and programmed my Uniden SDS100 with the Union simulcast and all the departments in Union. I’m only receiving Fire/EMS dispatches and units. I saw Mint Hill and Matthew’s units are secure. Just curious if anyone gets these dispatches or Union co sheriff?
Whiskey3JMC
DXpeditioner, RRDB & Google-fu ninja 4 hire
Philly burbs 🇺🇸
Sheriff shows partial encryption (mode "De") in the database meaning some transmissions can be tracked & others not so. Have you turned on the Law Tac & Law Talk service types so you can scan the talkgroups marked as such? (reference "Tag" column) Law dispatch is enabled by default unless turned off by user but the other two I mentioned are not. Someone local will need to weigh in regarding if they can still be tracked or if they've moved to full time encryption (definitely a possibility with today's climate)
DECHEXModeAlpha TagDescriptionTag
45596b21cDeUCSO Disp 1Dispatch 1Law Dispatch
45500b1bcDeUCSO C/W 2Countywide Operations 2Law Tac
45598b21eDeUCSO RecordsRecordsLaw Tac
45563b1fbDUCSO Ops 1Operations 1Law Tac
45564b1fcDUCSO Ops 2Operations 2Law Tac
45565b1fdDUCSO Ops 3Operations 3Law Tac
45519b1cfDeUCSO PrivatePrivateLaw Talk
45726b29eDUCSO PrivatePrivateLaw Talk
Medic8185
Charlotte,NC
Thanks for the info. Yeah I have those turned on. I suspect they may have moved to full encryption.
