I have Unitrunker working on two Motorola Type Systems, however, I am getting a very low decoding rate for a Edacs96 Type System. I am able to see and hear the groups talking to each other on Unitrunker, but it cuts off after a second or less. Unitrunker is unable to decode properly. The Site is locked on the Receiver folder and it is logging the Edacs System as it is attempting to decode it, but is unable to hold on to a specific Target Id. The priority on the listen groups is the defaut 50. I was having the same problem as others using Unitrunker creating Limbo systems, but the Site locked/Logging Enable seems to have worked for me, but occassionaly get the Limbo systems. How can I improve the decoding rate, I am assuming that the decoding rate might be the problem. I have also adjusted the squelch on the signal receiver and has not made a difference. I have messed with the sound card Recording Device and the signal becomes distorted after I raised the slider level. Most importantly, there is no improvement in the decoding rate. I am still learning how to use Unitrunker.
Any suggestions.
Thanks, TJ.
Any suggestions.
Thanks, TJ.
