UniTrunker P25 decoding tips...
Forts
Ontario, Canada
Anyone have any tips for P25 decoding with UT? I'm running release 19 from a tapped Maxtrac and I can only seem to get about 30% decode quality (EDACS decoding is 100% usually). I've tried messing around with my tap a little bit, as well as using the Mic in vs Line in (no difference). If I boost the volume in the mixer at all the decode rate seems to drop. My current tap is setup with a 10uf cap and 27k resistor, as well as a 4.7k between the cap an 27k to ground.
Even with this low decode rate UT seems to still work pretty well, however I'm fussy and would like to see a higher decode rate :)
Any tips appreciated!
Forts
Ontario, Canada
Very flat... as in basically a small ripple. As soon as I increase the volume slider in the mixer my decode rate drops to almost nothing.
slicerwizard
Toronto, Ontario
So you've wired it like so?
Code:
tap---10uF---+---27k---mic in
            4.7k
gnd----------+---------gnd
That's pretty much the same as
Code:
tap---10uF-------27k---mic in
gnd--------------------gnd
Neither provide the required voltage divider. Without it, 4 level decoding is really going to suffer.
The 4.7k goes after the 27k, not before.
Comint
Queensland, Australia
The correct voltage divider diagram.
Code:
tap---10uF---27k--+-----mic in
                 4.7k
gnd---------------+-----gnd
An alternative layout, which is electrically the same as above.
Code:
tap---10uF---+
            27K
             +------mic in
            4.7K
gnd----------+------gnd
Comint
Forts
Ontario, Canada
Thanks for the suggestions... I'll crack the radio and see how I did it, but I believe I have the 4.7k before the 27k.
Forts
Ontario, Canada
Well, moving the 4.7k actually made it worse. I was using the Line In on my sound card and the decode dropped from ~30% to 0. Switching to Mic In gives me about 15%.
bowser22
i put a 10uf cap and a 10k resistor inline of the tap like this
Disc---+10uf-----10k resistor--------Line In+
Gnd------------------------------------------Line in-
It dropped my audio levels so low dsd could barely discern the audio.
After i removed it and went straight through i get a clean decode of p25 with 40% inlvl.
gary123
on the maxtrac take your signal from P601 pin B. this is a buffered and high passed filter point. you should see an exellent waveform here.
I am using this point for DSD with exellent results. I do use a 10u cap for DC isolation.
Forts
Ontario, Canada
Thanks, I will look into that!
.... ok, where in the world is P601? I'm not seeing it here at all
Here is the waveform I'm currently getting..
The waveform is C4FM which explains the low decode rate. The program performs much better with CQPSK. This is a deficiency I'm working to improve.
Forts
Ontario, Canada
Ah ok, thanks for clearing that up! This is a new demo system that Harris is tinkering with, and the only P25 system within earshot for me.
Mike_G_D
Vista, CA
Odd - I always thought that C4FM was the "easy one" for everyone versus CQPSK being the tougher to deal with?
C4FM = Compatible 4-level Frequency Modulation - pretty easy to demodulate with basic FM hardware.
CQPSK = Compatible Quadrature Phase Shift Keying - not so much, especially with LSM and other multipath constructive and destructive phasing issues.
-Mike
Forts
Ontario, Canada
Hate to dredge this up again, but I'm still not having much success with Release 22. I moved the tap in my Maxtrac to Pin B for JP601 and same as before.... EDACS decode is excellent, P25 sucks (around 15% at best). Tap is setup as Comint described in post #6 above, and the waveform still looks the same as what I posted earlier.
Anyone else running a tapped radio on a C4FM P25 system and getting good decode? If so, would you mind describing your tap setup for me?
Thanks!
Update: I was able to pull in the MPSCS P25 system from Michigan tonight (which is CQPSK) at around 85-90% quality, so it seems my issues are only with C4FM systems.
GroundLoop
From what I can tell, pin B picks up the signal after the 3kHz low-pass filter, but BEFORE the 300hz high-pass filter. If you want the high-pass filter included, that should be "A", no?
