Unitrunker Preview
Here's a screenshot of the Site window in Unitrunker. Notice the split display.
More details to follow.
crazyboy
NJ
Awesome have been hoping for this
FlashSWT
Galveston/Houston, TX
Very cool. Since we're already moving this direction I'd love to be able to have the group or users list on the bottom panel like the old version also.
The groups and users tabs are located on the System window. Tying these tabs to the site window (particularly for systems with more than one site) would confuse people.
FlashSWT
I didn't even think about having more than one site going at the same time (I need a computer upgrade before I can do that). Makes total sense, sorry.
FlashSWT
Interesting, I assume that would require me to wire my discriminator taps a certain way?
I'm also not sure my Unitrunker computer is up to the task of a second site. It is an old laptop, 398 MHz Celeron with 192 MB of RAM.
You can get a dual mono to stereo adapter from Radio Shack or Fry's for $5 or so.
You can squeeze in more performance by turning off things you don't need. For example, if you only monitor Motorola, turn off P25, EDACS and MPT1327. If you know the signal polarity, select "normal" or "inverted" instead of "auto".
Liverdog
Rick,
If running two receivers, broken out left/right, will there be two windows for each system/site or will you have to tab over?
I'm asking 'cause the split display threw me off... Is the 'split' two separate systems/sites or just more info on single system/site, like affiliation activity. It hard to see...
[edit: Never mind. I see what's going on.]
Muxlow
Super Secret
Middlesex County
I tried this one the London EDACS system. They have 3 sites and i had 2 laptops running site 1 and 3. Now i can monitor both sites one 1 computer.
Althou i had a problem. The one site decodes 100%. The other does for a few seconds then shuts down. When i stop that radio and then turn it back to running i get the signal 100% again.
I know that the signal is running 100% thou.. My computer just dont want to let that signal keep going for some reason.
Im running this on my desktop compy with my new motherboard. I have Line IN and Mic IN that are in use for this... Or do i have it set up wrong?
mikea7531
South Bound Brook NJ
I'm looking forward to this release. The split screen design will be a major improvement to an already awesome program.
Any updates as to when the next release will be?
