Unprogrammed Pager
dough1590
Have repeatedly tried to transfer saved profile to a brand new G5 but I get an error message on the screen "Unprogrammed pager. Please use PPS to program before using". Can someone offer assistance on what I'm doing wrong?
JD21960
ILL-annoyed
Unication UNProgrammed Pager
You didn't describe exactly* what you did, just said you repeatedly tried to transfer.
The proper program method is to save everything, go through all the # steps and click "program" at the end, it takes you to the program page. With your pager hooked up by USB to the programming cable - your profile should be showing at the top. I always click the LINE and score it or double click it and then turn the scanner ON.It should show at the top the #1 meaning profile connected. If it isn't showing connected at top you won't transfer squat. The scanner takes a few seconds to recognize the program sequence.
dough1590
Thanks for veryone's help. After going through the profile step by step again found that I didn't have "trunk scan" checked only "monitor scan": Seems to be woirking fine now. Enjoying my new G5 in the Frisco Texas area covering 55 items so far on five knob positions in Zone 1.
