In reference to my previous post: Looking for input on antenna placement options... I promised to provide an update when my Mini Circuits ZBSF-95+ FM Notch Filter arrived.
First of all, this thing is beautifully made and built like a tank. The enclosure is machined aluminum. Very nice looking piece of kit. Also, I ordered it on Friday afternoon and it arrived today. Nice. I didn't expect it until at least mid-this week.
But more importantly, how does it perform? Well, everything is coming in better across the civilian air band. The lower range, where most of the local frequencies of note are located (118-120MHz), is noticeably better compared to the RTL-SDR FM Filter I was using. This isn't surprising, as the RTL-SDR is down -14dB at 118MHz... that's so bad. In contrast, the ZCSF-95+ is only down -2.9dB @ 118MHz; an enormous improvement.
This has drastically improved the reception of KDAY's Approach/Departure and Tower frequencies. Ground, as one might expect, is still pretty scratchy.,, it is 17 miles away after all. Unfortunately, though, the Brookville RCAG site for Indy Center still isn't where I'd like it to be. I can hear it, I can copy it, but just barely. The next step is the DPD Miltenna in the attic, but I really doubt if that will be a huge improvement over my Arrow 144/440 J-pole. I hope so, but if not, outside it is!
