RadioScannerSA
- Joined
- Dec 10, 2016
- Messages
- 24
Hi,
I currently have a WS1040 scanner mounted in my car connected to an outside antenna (https://rcw.co.za/wp-content/uploads/2022/05/5.-ANT-M-504-Mobile-Antennas-Highband.pdf).
I'm looking to upgrade to the SDS100 and so I have a couple of questions.
1. My WS1040 scanner is on the whole day when I'm driving, using a car power adapter. Can I do the same with the SDS100 by plugging it into the USB port? Can it handle that without overheating or killing the battery?
2. WS1040 has a BNC antenna, can the SDS100 connect to it the same via an adapter?
3. The main reason I'm upgrading is that sometimes the Whistler picks up frequencies, but it makes a noise like this: http://www.w2sjw.com/sounds/DMR_TDMA.mp3. I've now read that it is most likely that the frequency is DMR and the WS1040 can't decode those, but the SDS100 can. Is this true? Can anyone confirm this? And would I need a further upgrade on the SDS100 to listen to those? Or is it the digital 1 that is included in the SDS100? Would an encrypted frequency also make that noise? Because I'm actually not sure if the frequencies are encrypted or not.
4. SDS100 is very much focused on the zip code feature. I live in South Africa so it isn't supported. I usually just work finding new frequencies using the limit search and the close call function, and I want to transfer all the analog frequencies I have saved on the WS1040 to the SDS100. Is it as simple as that? Or is the SDS100 useless outside of USA/Canada?
