So i was brainwashed into going to the local ham store and buying a BNC T today. I hooked it up in place of my multicoupler that works fine with all 5 of my other scanners...
To the point...
in the beta forum i was instructed to use a BNC T instead of a multicoupler to see if the vhf signal bleed was from my multicoupler...
So antenna to BNC T then coax from BNC directy to sds100 and other end of BNC T directly to my bcd996p2.
The 996P2 still recieves like brand new...
However the sds100 since being recommended by someone in forums to hook 2 scanners to a BNC T no longer even receives the local weather that used to ghost over to the whole vhf high band and overload only vhf hi band... now even my UHF chnnels do not come in...
Why should I have to pay as the repair person said on the phone because its an unisolated BNC connection that burned it out?
I believe the ONE who recommended this action as a Uniden Fan should pay for this repair as he stated to do this and blamed the multicoupler..
Is this true that hooking 2 scanners through a BNC T will do as uniden tech said and burn out the scanner as someone recommended I needed to do in the public forum for the sds 1.05.00 open beta.. Unfortunately most of that conversation was blown out of proportion and deleted by admins..
How can this be fixed?
To the point...
