Anyone have any information for radio frequencies for upmc Northwest hospital or what system they use?
i seen their radios it looks like VHF and don't look DMR but i could be wrong. They don't talk much on them like the bigger hospital do. but thanks for the quick reply.Nothing ID'ed in the RRDB but I'd suspect conventional DMR given the info listed for the other ID'ed locations
FCC Callsign WRFG848 (U P M C NORTHWEST MEDICAL)
FCC Callsign WRFG848 (U P M C NORTHWEST MEDICAL)www.radioreference.com
Thank you for that information.I live 3 miles away from NW. They do have a DMR system but the way the antenna system is setup it can only be heard on property and very close. Last time I checked the main repeater was still setup in mixed mode as my fire dept still has access to talk to security in analog. I have not had the time to sit in the parking lot and gather any info yet.
Does the UPMC med AVC copters use the same frequency including the Muncy UPMC copterNothing ID'ed in the RRDB but I'd suspect conventional DMR given the info listed for the other ID'ed locations
Try here
Not sure what you're asking, UPMC doesn't have any helicopters that I'm aware of. StatMedevac and AGH Lifeflight are the main helicopters that serve the area. They generally coordinate landing on the pad thru Statcom over the phone. My fire dept used to handle 2nd lzs there but UPMC installed a gate on the ER road and they let them use that now for when the pad is full. We've also put them on the grass hill above by behavioral health and in the parking lot when it was empty. That was about the only time they used radios for the choppers was 2nd lz to the fire dept.Does the UPMC med AVC copters use the same frequency including the Muncy UPMC copter
So far there is no license in Lycoming for the Stat Helicopter at Muncy, there is an assumption that they are using the Stat frequencies that are listed in the RR Database for Pennsylvania.Does the UPMC med AVC copters use the same frequency including the Muncy UPMC copter
