Urgent help required!!!
Shruti01
Hi ppl,
In SDR, the RF signal is converted into IF signal by A to D converter. The received signal is a set of sample points. Based on symbol rate/baud rate/bit rate, the received signal has to be identified whether it is amplitude, frequency or phase modulated and decode the original signal if necessary. I mean how to detect whether the received signal is using BPSK, QPSK modulation technique.
Thanx.
kmorgan
Hauppauge, NY
Good article
Hi ppl,
Thanx.
Here's one of the better articles in PDF format that explains demodulation techniques for the I and Q signals generated by SDR.
http://www.nonstopsystems.com/radio/article-sdr-is-qs.pdf
