comfirming 170.800 in Central Alabama ( montgomery) heard p25 ENC this date
Confirming as USM? Did you get a NAC?
Phil![]()
no nac with Pro 96, I should have my 197 in the next Month or so, waiting for an F&F discount hhe
at least I thought it was what was posted here as being for USMS![]()
ok, I got from here & I thought someone had already verified as b USMS??Roger on the 197. Good scanner with an FM broadcast band filter in line.
I have heard USM use this a long long time ago here in FL. I believe it was the input to 162.7125, but this is also a place where some Prison stuff is as well as ICE, and every location may be different, so you need a little more to go on. The NAC helps.
Phil![]()
if i remember correctly someone told me they used the INS systems, which may have been what was also referred to above asDOJ system.
I'm new to digital scanning, having just gotten a 396XT this week. I've programmed in a number of the frequencies mentioned in this thread and set them for "All" audio. From time to time throughout the day, the scanner will stop on one of the frequencies and I will hear a sound like an open squelch, but no intelligible transmission.
Is this because the frequency is in use but encrypted, or am I doing something wrong in my setup which prevents me from hearing these transmissions?
I don't mean to hijack the thread, so if this requires more than a quick answer, just let me know and I'll start a separate thread.
Thanks.
Dick
No problem, and congrats on the new scanner!
What freqs are you hearing this on? How strong is the signal (bars?) Collect and present any PL or NAC you get so we can have something to go on. That info is the stuff to grab!
It is possible your squelch is opening due to being set too low. It is also possible you are picking up analog encryption. Analog encryption (DES-XL) has a high pitched squeel at the end of the transmission, so if you are hearing that, you know what it is.
Give us more info! I wonder if USM has any analog left in any area of the country.
EDIT: I'm in the midle of a screaming band opening to my south! Outragous strong signals and quiet noise floor. Even DTV DX is good! Lots of new stuff to follow.
Phil![]()
Thanks, Phil.
I noted this again today on 167.2125, 167.375, 167.725, and 170.7125. I had the squelch set to maximum to make sure that wasn't the problem. I didn't notice any high pitched squeal at the end of the transmissions. I was unable to note either NACs or PL codes since in the "All" setting for the audio neither can be searched on my scanner. When I reset these frequencies to Digital and NAC search, I no longer heard the noise that I described. The frequencies were then silent all afternoon.
The only thing that I've heard on any of the "federal" frequencies today other than this open squelch sound was on 165.375 on which I heard a warbling sound for perhaps 30 seconds.
Thanks for your help.
Dick
I suspect that you are receiving FBI voice encrypted transmissions. It is most likely Motorola (DVP/DES or varient) Securenet voice privacy, from what you describe. The body of the message sounds like open squelch on a radio that is not connected to an antenna. The tell tale high pitched squeal at the end of the transmission that Phil mentioned is only a few hundred milliseconds long so you may have missed hearing it. The high pitched squeal tells the receiving radio that it is the end of transmission.
Your scanner will only output audio for this type of signal if in a mode that will only pass carrier squelch.
Listen to http://www.kb9ukd.com/digital/des.wav If you listen carefully, you can hear the high pitched tone at the end of the audio sample.
165.375 is a well known Secret Service frequency.
Squad10,
Thanks very much. That's extremely helpful. The wav file sounds like what I've been hearing and I had to listen to it a number of times before I even heard the high pitched squeal. Perhaps my high frequency hearing ain't what it used to beI could certainly have missed hearing it on the radio. Now that I know what it sounds like I can specifically listen for it to confirm that's what I'm hearing.
That also explains why when I reset the Audio to "Digital" the sound no longer shows up since, as I understand it, it is no longer looking only for just a carrier but also a digital signal that it can decode.
So would I be correct that I should set these "federal" frequencies on which I hear this sound to digital and the NAC to search to maximize hearing any transmissions that might be in the clear and yet to avoid hearing the open squelch noises? I guess I should leave others on All in case they are still using analog. Is this the best bet?
Thanks!
73
Dick
Phil,
Any reason to set PLs (or NACs) on these FBI, USM, etc. frequencies? Perhaps I'm missing something in the interaction between the analog and digital.
Thanks again for taking the time to help out.
73,
Dick
