USAF EAM transmission
freyhaus1
FTWB, FL
...USAF EAM network transmission July 9 2024 at 0029 UTC on 11.274.95 Mhz USB
"Billboard, Billboard, this is Nightfall... authenticate Delta-Alpha-Lima"..."Nightfall, Nightfall, this is Billboard, I authenticate Delta-Alpha-Lima as India"...roger Billboard, you have entered the net at 0032 UTC, out"...
bearcatrp
Land of 10,000 taxes
Used be allot on 11275 awhile back. Not to much lately though. There is a thread somewhere that lists all the EAM freqencies.
dlwtrunked
That is not an EAM transmission, I am not sure why you called it one. It is a simple entering into the net with authentication to prove who they are. That is not an EAM unless they also transmitted one. And other nets use this same procedure.
freyhaus1
FTWB, FL
...entering onto the net for an authentication is a valid transmission on that net...i did not say anything about about a message being transmitted...
dlwtrunked
I thought that is what I said. In no place in your quote did you say you actually quote an EAM, you only posted about hearing an authentication for a net log in. If that is all your heard, then it is not an EAM transmission. I just wanted to be certain that you did not consider that an EAM.
