XPR USB Device not recognized
ShawnClitso
Farmington, NM
I've recently purchased an XPR4550, and I've been unsuccessful in trying to program it. I keep getting the error, "USB Device not Recognized; The last USB device you connected to this computer malfunctioned, and Windows does not recognize it." I've tried downloading and reinstalling some drivers, however those haven't successfully resolved the issue. My XPR7550e has had some issues, but I am still able to program it without much issue. Is there anything that I'm missing?
com501
What O/S ?? What version of CPS? What is the F/W rev of the radio in question?
a417
Do you have another programming cable?
Golay
Nankin Township Michigan
It's been a bit since I've programmed Trbo. Is this the error that can be overcome by going into Administrator Mode (or what it's called)?
Or am I thinking of something else?
ShawnClitso
Farmington, NM
It might be a Windows error of some sort, the cable itself is not being recognized in my device manger. I'm unsure as to if I'm missing a driver or what
ShawnClitso
Farmington, NM
Try turning your WiFi off. The CPS is looking for a network connection. Once connected to the radio, give it enough time for the New Network screen to pop up.
I was able to try, unfortunately with no luck. It's still giving me the same error so I'm unsure as to where to proceed
K2NEC
5F6
That's probably your issue. Is it a front cable or a rear cable?
Twlighting
Los Angeles, CA
For what it's worth, I purchased an aftermarket USB cable for the front connector, could never get it work with XPR mobiles, but have had zero issues with APX/XTL mobiles. Ended up getting a USB cable for the rear XPR connector an that has been trouble free.
ShawnClitso
Farmington, NM
I’m hoping that fixes the issue, thank you for your help
K2NEC
5F6
Same issue for me. I couldn't get my aftermarket cable working and I almost got a rear cable but was able to find a cheap OEM cable on ebay for just about the same price so I went with that instead.
