Well, I've been using the car's f/m antenna for a few days now. I live in King George, VA which runs off of vhf. I can pick them up just fine. Range is a little more limited as opposed to an actual scanner antenna, but I can still get coverage over the whole county. I also scan a few other vhf systems and they work fine also. I do however scan 1 uhf system and 1 800mhz system. The uhf system I can pick up while mobile, but I encounter a few dead spots within the county. The 800mhz system I can pick up mobile only in one spot of the county, anywhere else in the county I have to be stopped.
So, all that said, I overall like the setup considering I can listen to all but one of the systems I scan. But, if you do alot of 800mhz scanning, I would avoid this option.
Regards, Jerry
